- Thank you received: 7
Solved An option to adjust the size of the text of posts returned when searching
2 years 7 months ago - 2 years 7 months ago #230679
by lemur
Signature:
Many thanks to Rich and the other advisors.
Good afternoon,
Please tell me if I'm wrong, but in Kunena there is no option to adjust the size of the text of posts returned when searching.
Specifically, if I use the forum search option, all posts that match the search criteria are returned.
At the same time, each post, even a very large one, is displayed in its entirety!
But this is absolutely unnecessary: to understand whether the user found what he was looking for or not, a few lines are usually enough. All the rest of the text is just a burden, as it requires scrolling, etc.
I propose to create a system parameter to limit the size of posts returned during searches. You can give also this parameter in the search form, but as long as it is not reset every time. (Theoretically, you can add this parameter to the user settings, but for me this is unnecessary).
Since the number of lines is a highly device-dependent value, I suggest limiting the number of words, or even better, characters. For example, 50 words or 160 characters - it is set by the admin in the settings.
Thank you
Thank you
Signature:
Last edit: 2 years 7 months ago by lemur.
- Thank you received: 2538
2 years 7 months ago #230704
by rich
Replied by rich on topic An option to adjust the size of the text of posts returned when searching
You can limit it via CSS. This code entry in
custom.scss
limits the search results to approx. 5 lines.
It has the advantage that you can scroll individual results if necessary.
/* --- Abbreviate search results --- */
#kunena_search_results .kmessage {
height: 100px;
overflow: scroll !important;
2 years 7 months ago - 2 years 7 months ago #230786
by lemur
Signature:
Replied by lemur on topic An option to adjust the size of the text of posts returned when searching
Thanks for the quick response,
this method works.
And indeed, It has the advantage that it can scroll individual results.
Perhaps a system parameter would be useful as well. At least he would have been known explicitly, and I wouldn't have had to ask for help.
Thanks again.
this method works.
Thanks again.
Signature:
Time to create page: 0.207 seconds
