- Thank you received: 1
Solved Incorrect display of categories
I'm having an issue with word merging (category names and the number of topics in parentheses - marked in the photo. This happens in all browsers, regardless of the zoom level). I know that the "list-inline" style is used for the text here. Also, if I'm not mistaken, the text is within a table. Right now, I can't find the appropriate selectors to fix the CSS. If anyone knows, please help! Which specific selectors are responsible for the table or the words inside it in Kunena?
Alternatively, maybe there's another way without editing the CSS. Perhaps instead of editing the CSS, we could simply disable the display of subcategories and the number of topics in them? That would work for me too!
System info: Joomla! 5.0.1 / Cassiopeia / Kunena 6.2.2
Attachment not found
- 9themestore
- Premium Member
Please let me know your website url (post to here or send to our mailbox) I will check and provide you with a solution to solve the above problem.
Regards,
- 9themestore
- Premium Member
Open the custom.css file in the "media/kunena/core/css/custom.css" folder and add below css rules to the bottom of file to solve your issue:
Regrads,
