Solved customizing avatars
2 years 11 months ago #230013 by ita4012
customizing avatars was created by ita4012
HI. I would like to customize the avatars of users who have not chosen their own.
I tried replacing nophoto.png, in the media/kunena/avatars folder, but it didn't work.
So what should I do?
Thank you
2 years 11 months ago #230017 by rich
Replied by rich on topic customizing avatars
Replacing the image is not a good idea, it would be replaced with every upgrade. Use the name of your own image in the Default avatar field.
And in the Default avatar type field, select Image instead of Icontype. Then empty the Joomla and browser cache if your avatar is not displayed.
The following user(s) said Thank You: ita4012
2 years 11 months ago #230024 by ita4012
Replied by ita4012 on topic customizing avatars
Ok. Doing like you suggested, I managed to change the default avatar.
