Solved Lost tooltips
3 years 1 month ago - 3 years 1 month ago #229490 by makitso
Lost tooltips was created by makitso
Joomla 4, Kunena 6.  Somewhere along the line I turned off tooltips and now I would like them to be turned on again.  Where is this set?
I found the setting, close issue.
Joomla 6.1.0
Kunena 7.0.3
Last edit: 3 years 1 month ago by makitso. Reason: Found solution
3 years 1 month ago - 3 years 1 month ago #229491 by Leen
Replied by Leen on topic Lost tooltips
Maybe in the kunena Aurelia template setting under the advanced tab?
Or have you ever made an override in Joomla Template?
And if not, please provide the name of the Joomla template used here, perhaps that could be the reason
ps
I saw too late that you had already found it
With kind regards
Leen
Last edit: 3 years 1 month ago by Leen.
