Solved Problem with custom user colours
3 years 2 months ago - 3 years 2 months ago #229255 by Konsider
I was in the process of editing the custom.scss using the following:
.kwho-admin { color: #FF0000 !important; } .kwho-globalmoderator { color: #800000 !important; } .kwho-moderator { color: #0000FF !important; } .kwho-user { color: #5388B4 !important; } .kwho-guest { color: #666666 !important; } .kwho-banned { color: #A39D49 !important; } .kwho-blocked { color: #ff0000 !important; }
When changing one of the colours and then saving, i accidently included an extra hash, meaning I got a "parse error". I then cleared the code, saved and the colours went back to the default. However, now when I try to edit things again, nothing happens.
How can I get it to work again?
Thanks!
Last edit: 3 years 2 months ago by Konsider.
3 years 2 months ago #229256 by Leen
Hi .
just to be sure which version kunena? and possibly your code was not completely complete?
and which custom.scss do you mean the one in kunena Aurelia or in your joomla template?
/*test*/ .kwho-admin { color: #FF0000 !important; } .kwho-globalmoderator { color: #800000 !important; } .kwho-moderator { color: #0000FF !important; } .kwho-user { color: #5388B4 !important; } .kwho-guest { color: #666666 !important; } .kwho-banned { color: #A39D49 !important; } .kwho-blocked { color: #ff000 !important; }
With kind regards
Leen
3 years 2 months ago #229257 by Konsider
It's Aurelia with the latest Kunena.
Changing the colour with the custom.scss was working fine until I made the typo and it gave me a parse error upon saving. Now, I can either remove the custom and it goes back to normal, or if I try any custom code nothing happens. Something obviously went wrong with the database. Can I reset this somehow in PHPMyAdmin?
3 years 2 months ago #229258 by Leen
ha okay I think I understand now that you wanted to adjust the colors of users?
then I think my code works as it should in the custom scss so you can convert it back to your own colors
/*test2*/ #kunena.layout .kwho-admin {   color: #2a0fe8 !important; } #kunena.layout .kwho-globalmod, #kunena.layout .kwho-globalmoderator {   color: #72bd18 !important; } #kunena.layout .kwho-user {   color: #d7dd17 !important; } #kunena.layout .kwho-blocked, #kunena.layout .kwho-banned {   color: #f70808 !important; } #kunena.layout .kwho-guest {   color: #e317d7 !important; }
With kind regards
Leen
3 years 2 months ago #229260 by Konsider
Unfortunately, it's not working for me. I think something definitely got corrupted when I had the error. That's unfortunate. Still, thanks for taking the time to try to help :)
3 years 2 months ago #229261 by Leen
Too bad that doesn't work
Have you ever cleared your Joomal cache or does that help?
and what error message do you get exactly?
If you empty the custom.scss and save it, do you also get that error message?
With kind regards
Leen
The following user(s) said Thank You: Konsider
