- Thank you received: 2
Solved Problem with custom user colours
When changing one of the colours and then saving, i accidently included an extra hash, meaning I got a "parse error". I then cleared the code, saved and the colours went back to the default. However, now when I try to edit things again, nothing happens.
How can I get it to work again?
Thanks!
just to be sure which version kunena? and possibly your code was not completely complete?
and which custom.scss do you mean the one in kunena Aurelia or in your joomla template?
With kind regards
Leen
Changing the colour with the custom.scss was working fine until I made the typo and it gave me a parse error upon saving. Now, I can either remove the custom and it goes back to normal, or if I try any custom code nothing happens. Something obviously went wrong with the database. Can I reset this somehow in PHPMyAdmin?
then I think my code works as it should in the custom scss so you can convert it back to your own colors
With kind regards
Leen
Have you ever cleared your Joomal cache or does that help?
and what error message do you get exactly?
If you empty the custom.scss and save it, do you also get that error message?
With kind regards
Leen
