Solved Forum Categories not displaying Full Page
3 years 8 months ago #227615 by squirrel333au
I have installed the latest version of the forum and displays as I want it but when a user opens a category it displays with side modules which are not required.
How do I stop the side modules from displaying?
3 years 8 months ago #227616 by Leen
That actually has nothing to do with kunena itself.
You will with every module that appears in kunena
by the Menu Assignment tab  uncheck the kunena pages and save the module
With kind regards
Leen
The following user(s) said Thank You: squirrel333au
3 years 8 months ago #227617 by squirrel333au
Thanks but that is not the issue as the only item checked for the modules is the Home Page.
When the topics open they appear within the home page not on a new page.
I can not work out what is going wrong.
Thanks again, I will try and find another forum extension.
3 years 8 months ago - 3 years 8 months ago #227618 by Leen
maybe I don't understand correctly.
but you mean that other joomla modules appear next to kunena forum ?
Can you post a link to your website or a picture of your problem?
And is the Cassiopeia Site template used or another one, then give the name of that template
With kind regards
Leen
Last edit: 3 years 8 months ago by Leen.
3 years 8 months ago #227706 by squirrel333au
I have replied to this several times but keeps on disappearing, mmmm
OK, here I go
The issue is that the forum "Create Account" page from the Login Drop Down opens up on the home page with the side modules displaying.
I don't have them set in Menu Assignments.
I am going around in circles trying to solve this issue.
If you click on create account from within a topic/category it displays correctly.
I am using Joomla 51 - Nina Template, Joomla 4
3 years 8 months ago - 3 years 8 months ago #227707 by Leen
