Solved Forum Categories not displaying Full Page
- squirrel333au
How do I stop the side modules from displaying?
You will with every module that appears in kunena
by the Menu Assignment tab uncheck the kunena pages and save the module
With kind regards
Leen
- squirrel333au
When the topics open they appear within the home page not on a new page.
I can not work out what is going wrong.
Thanks again, I will try and find another forum extension.
but you mean that other joomla modules appear next to kunena forum ?
Can you post a link to your website or a picture of your problem?
And is the Cassiopeia Site template used or another one, then give the name of that template
With kind regards
Leen
- squirrel333au
OK, here I go
The issue is that the forum "Create Account" page from the Login Drop Down opens up on the home page with the side modules displaying.
I don't have them set in Menu Assignments.
I am going around in circles trying to solve this issue.
If you click on create account from within a topic/category it displays correctly.
I am using Joomla 51 - Nina Template, Joomla 4
With kind regards
Leen
