Solved Could be a bug
3 years 11 months ago #227039 by anonymous01
Could be a bug was created by anonymous01
Hi all. I may well have stumbled upon a little forum bug. I haven't investigated the problem thoroughly or analyzed the code. But nevertheless.
If a moderator converted a post to a category topic, the category topic counter is able to display an incorrect value. Tell me, @xillibit, is my description of the problem perhaps familiar to you? It's easily reproduced.
Kunena 5.2.14, php 7.4.
I haven't had time to try it on Kunena v.6 yet.
3 years 11 months ago - 3 years 11 months ago #227047 by rich
Replied by rich on topic Could be a bug
I've tested it. Recount Statistics fixes the incorrect values.
Last edit: 3 years 11 months ago by rich.
The following user(s) said Thank You: anonymous01
3 years 10 months ago #227052 by anonymous01
Replied by anonymous01 on topic Could be a bug
You are right.
