Solved Avatar - Gif
5 years 1 month ago #219492 by Hifi2you
Avatar - Gif was created by Hifi2you
Hi
Is it possible to do so you can use GIF as an avatar on your profile, ie with movements ?
5 years 1 month ago #219495 by rich
Replied by rich on topic Avatar - Gif
Should be, but the easiest way to find out it, if you test it.
5 years 1 month ago #219507 by Hifi2you
Replied by Hifi2you on topic Avatar - Gif
Then it is tested and does not work.
The picture is still.
This is the Gif I've tried
5 years 1 month ago - 5 years 1 month ago #219513 by rich
You must resize it before upload. Try it with this image.
Last edit: 5 years 1 month ago by rich.
5 years 1 month ago #219518 by Hifi2you
It was a little better, now it works when you click on a thread, but the Gif stands still on the front page.
But thank you
5 years 1 month ago - 5 years 1 month ago #219519 by rich
Kunena cannot edit images, this is done by the image software GD library installed on your server. This library resize the images but saves not as animated.
You mean the small avatar on the front page?
If it is for your own avatar, use a trick. Replace this small image in the folder /media/kunena/avatars/resized/size36/users/avatarxxx.gif
Rename this image, instead of the xxx (avatarxxx.gif) you must enter your user ID.
Then you have also an animated avatar on the front page.
