Solved Uninstall without losing data
5 years 2 months ago #218886 by autobahn
My test site currently has Kunena 5.2.6. Version 5.x is never going to be compatible with Joomla 4 so I need to uninstall it and then install Kunena 6 Beta after I have done the Joomla 4 upgrade - I'm just testing everything at present. If I uninstall the current version of Kunena will I lose all my forum data? I can backup the table and re-import them if need be.
Alternatively, I can try disabling all the Kunena plugins etc to try to get rid of the Joomla Pre-Update checker incompatibility message. Has anyone tried this?
5 years 2 months ago #218887 by rich
Replied by rich on topic Uninstall without losing data
In principle, you lose nothing when you uninstall Kunena via the Joomla extension manager.
Additional, you can to export all Kunena tables and make a copy (backup) of this both folders:
media/kunena/attachments
and
media/kunena/avatars
Then you are on the safe side.
Hint: Currently is an upgrade from Kunena 5.2.6 to K6.0 not yet possible.
The following user(s) said Thank You: 9themestore, autobahn
5 years 2 months ago #218890 by autobahn
Thank you :)
Time to create page: 0.099 seconds
