Solved disable kunena login
5 years 3 months ago #218668 by [email protected]
Is there a way to disable kunena login and route it to site custom social login instead?
5 years 3 months ago #218677 by rich
Replied by rich on topic disable kunena login
I don't know your custom module. Can it be displayed horizontally? I also don't know which Kunena template you are using.
Go in the backend to Kunena -> Plugins and disable the plugin Kunena - Joomla Integration and to place a duplicate of your custom module on kunena_top.
5 years 3 months ago #218693 by [email protected]
that worked .. thanks. I was able to use my custom social login module.. thanks Rich..
