Solved Did Kunena finally have a “Solved” Topics button?
5 years 3 months ago #218576 by Chacapamac
I was just wonder if topic starters can finally mark their topic as “Solved” and were is the settings to put it on ?
5 years 3 months ago #218628 by 9themestore
My solution: The author post can edit topic and change the icon of topic to "solved" icon.
5 years 3 months ago #218629 by Chacapamac
I think this work only if you edit the first topic on older version.
Even worst, the version that’s running here now doesn’t let you do that, or the possibility is hidden somewhere????
The ability to have an easy resolved button (with the other action buttons) and not in some hidden part of the interface is primordial for both Post Authors and Forum Administration.
Having that visual “Solved” tag permit the post authors the see their unanswered questions in an instant and make a rapid visual cue of what is what on the forum.
Look at the picture attached - No more or hidden ability to change the icon of the topic to “Solved”?????
5 years 3 months ago #218630 by rich
You have to look in your own forum. Here on k.org are selectable topic Icons disabled.
5 years 3 months ago #218631 by Chacapamac
Ok, Good, at least we didn’t loose that, thank you Rich....
If this is the only way in Kunena to mark a topic SOLVED this is not really user friendly?
5 years 3 months ago #218634 by rich
Unfortunately, that is the only option currently. I don't know if it's on our to-do list for Kunena 6.0.
The following user(s) said Thank You: Chacapamac
