Solved Advanced search layout is wrong
5 years 5 months ago #217676 by kominid
Hi, I am having an issue with 2 elements with kunena layout.
1. Is the layout of the advanced search section on the search menu item.
2. The login button on the nav bar doesn't seem to be working correctly.
I have attached a photo and the configuration report.
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 2M
Joomla default template details : dronzColours912 | author:  | version: 1.0 | creationdate: 2021-05-09
Kunena default template details : Crypsis | author: Kunena Team | version: 5.2.4 | creationdate: 2021-04-04
Kunena template params:
Kunena version detailed: Kunena 5.2.4 | 2021-04-04 [ Koios ]
Plugins: None
5 years 5 months ago #217685 by rich
Which Bootstrap version use your Joomla template? Maybe there is a CSS conflict, but that's cannot be seen in a picture. Have you a link to your forum?
5 years 5 months ago #217716 by kominid
Hi again, unfortunately the site isn't live so I can't link you. But I have narrowed it down to this element of the search page (see pic)Also, I am using this version 2.3.2 of bootstrap but it appears the site is using bootstrap.min.css rather than bootstrap.css? (see version pics)
Thanks for having a look.
Dom
5 years 5 months ago #217721 by rich
Try to disable the option "Load Bootstrap CSS" in the Crypsis setting.
Or search the issue with the method of elimination. Test it first with the Joomla default template Protostar. Is the error still present, disable all non default extensions one by one, to find the cause.
Unfortunately, I cannot help more without seeing it.
The following user(s) said Thank You: kominid
5 years 5 months ago - 5 years 5 months ago #217727 by kominid
Hi again, Thanks for all your help rich. I managed to fix the problem with some funky css lol.
I have attached an image so you can have a giggle at my css skills!
it's working on desktop but i shudder to think what it will do responsively?
##EDIT##
Is there a way to separate the custom.css between responsive and desktop mode?
Regards
Dom
Last edit: 5 years 5 months ago by kominid.
5 years 5 months ago #217785 by rich
Yes, it's possible, if you address it to the desktop size.
In this example, the code effect begins from a size of 1024 px.
@media (min-width: 1024px) {   #kunena.layout select#mode {     margin-left: 165px;     margin-bottom: 0px;        } }
Time to create page: 0.187 seconds
