- Thank you received: 1
Solved Incompatibility between Kunena and Helix Ultimate II
5 years 5 months ago - 5 years 5 months ago #217016
by godorizzi
Incompatibility between Kunena and Helix Ultimate II was created by godorizzi
I am having a hard time figuring out what could cause an issue with my website: www.flavioodorizzi.com/forum/
I am using Helix ultimate II as template and Kuena.
Chrome DevTools shows an error:
that I suspect is making the forum's template messed up and partially not working (e.g.: the "action" and "moderation" buttons are not functional at all).
I googled a bit and it turns out this could be related to a conflict between jquery and bootstrap, but I am at loss as what to do to solve this issue.
Any help would be greatly appreciated. Thank you.
Uncaught TypeError: $(...).modal is not a function at HTMLDocument.
Last edit: 5 years 5 months ago by godorizzi.
5 years 5 months ago #217017
by ssnobben
Replied by ssnobben on topic Incompatibility between Kunena and Helix Ultimate II
hope you get this sorted I plan to use Helix Ultimate v2 with Joomla 4 & Bootstrap 5 with php 8 support.
- Thank you received: 2538
5 years 5 months ago #217021
by rich
Replied by rich on topic Incompatibility between Kunena and Helix Ultimate II
We don't have a template for Bootstrap 5 yet and for Joomla 4 will be available Kunena 6. This version is under development and not yet ready.
5 years 5 months ago #217024
by xillibit
Replied by xillibit on topic Incompatibility between Kunena and Helix Ultimate II
Kunena 5.2.x supports already Php 8.0.x like Joomla! since 3.9.24hope you get this sorted I plan to use Helix Ultimate v2 with Joomla 4 & Bootstrap 5 with php 8 support.
5 years 5 months ago #217027
by godorizzi
Replied by godorizzi on topic Incompatibility between Kunena and Helix Ultimate II
Hi rich,
so is this an incompatibility between Kunena's Bootstrap 4 and my template's Bootstrap 5?
Is there a workaround?
5 years 5 months ago #217028
by rich
I'm sorry, but I don't know a workaround.
But I see on your web site other errors which are present outside from Kunena pages like on Contattami
or
Dove lavoro
Therefore, I think errors are generally present. In principle the forum looks good. I'm not sure if it's a good suggestion, to ignore the errors. But if your forum in spite of this warning works, it would be a possibility.
Uncaught TypeError: $(...).collapse is not a function
Dove lavoro
This site overrides Array.from() with an implementation that doesn't support iterables, which could cause Google Maps JavaScript API v3 to not work correctly.
