Solved Incompatibility between Kunena and Helix Ultimate II
5 years 7 months ago - 5 years 7 months ago #217016 by godorizzi
I am having a hard time figuring out what could cause an issue with my website:  www.flavioodorizzi.com/forum/
I am using Helix ultimate II as template and Kuena.
Chrome DevTools shows an error:
Uncaught TypeError: $(...).modal is not a function at HTMLDocument.
that I suspect is making the forum's template messed up and partially not working (e.g.: the "action" and "moderation" buttons are not functional at all).
I googled a bit and it turns out this could be related to a conflict between jquery and bootstrap, but I am at loss as what to do to solve this issue.
Any help would be greatly appreciated. Thank you.
Last edit: 5 years 7 months ago by godorizzi.
5 years 7 months ago #217017 by ssnobben
hope you get this sorted I plan to use Helix Ultimate v2 with Joomla 4 & Bootstrap 5 with php 8 support.
Joomla 6.2.1 PHP 8.5.12 MariaDB 12.3.2 with new EasyBlog, EasySocial fork from Creative Graphics! CRE8 Social creative-graphics.ch/software/easysocial CRE8 Blog www.cre8.blog/ no Behaviour compat6 plg needed!
5 years 7 months ago #217021 by rich
We don't have a template for Bootstrap 5 yet and for Joomla 4 will be available Kunena 6. This version is under development and not yet ready.
5 years 7 months ago #217024 by xillibit
Kunena 5.2.x supports already Php 8.0.x like Joomla! since 3.9.24
5 years 7 months ago #217027 by godorizzi
Hi rich,
so is this an incompatibility between Kunena's Bootstrap 4 and my template's Bootstrap 5?
​​​​​​Is there a workaround?
5 years 7 months ago #217028 by rich
I'm sorry, but I don't know a workaround.
But I see on your web site other errors which are present outside from Kunena pages like on Contattami
Uncaught TypeError: $(...).collapse is not a function
or
Dove lavoro
This site overrides Array.from() with an implementation that doesn't support iterables, which could cause Google Maps JavaScript API v3 to not work correctly.
Therefore, I think errors are generally present. In principle the forum looks good. I'm not sure if it's a good suggestion, to ignore the errors. But if your forum in spite of this warning works, it would be a possibility.
