Solved Spell check yields a "Paste" button with Kunena 5.2.3
5 years 7 months ago #216670 by KZQ
Hi Folks,
I really like this new version except for a few issues that I'm sure will be ironed out soon. The biggest issue I have is that if I misspell a wrod I get a paste box instead of suggested correct spellings. I've looked through the whole backend and cannot find a way to correct the Spell Check.
Any help will be greatly appreciated.
Bill
5 years 7 months ago #216678 by rich
Go to /media/kunena/core/js/ and copy the ckeditor_config.js and add to the copied file a prefix like customckeditor_config.js
Open the custom file and add on top this code (red marked):
CKEDITOR.editorConfig = function( config ) {
    // Define changes to default configuration here. For example:
    // config.language = 'fr';
    // config.uiColor = '#AADC6E';
    // config.skin = 'moono-lisa';
       config.scayt_autoStartup = true;
Source: ckeditor.com/docs/ckeditor4/latest/guide/dev_howtos_scayt.html
Now go in the backend to "Kunena -> Templates -> your Kuneena template -> tab BBCode" and scroll down. Enter to the prefix field the custom word (in this case custom) and save it.
It would also work if you edit the original file, but the custom file will not overwrite if you upgrade Kunena.
The following user(s) said Thank You: KZQ
