Solved Text direction and map buttons
5 years 10 months ago #215296 by 2078b54a0a6a52c894ea0efa
Using K5.2.2 with latest Crypsis template.
I can't find any way to do this in the configuration - is it possible to disable the text direction and also map buttons in the editor ?
5 years 10 months ago #215302 by rich
Replied by rich on topic Text direction and map buttons
Go in the backend to Crypsis -> tab BBCode. Here you can disable unneeded symbols.
5 years 10 months ago #215315 by 2078b54a0a6a52c894ea0efa
Thanks rich.. although I still can't seem to remove the text direction symbols - any ideas ?
Also.. at the very bottom of the Crypsis > Bbcode page, there's an option to set the name of the CK Editor skin ('the skin should exist in the skins directory') - I can't find that anywhere, where is that directory located?
Thx again :)
5 years 10 months ago #215319 by rich
I've tried it and it works. Maybe you must empty the Joomla and Browser cache.
You need this only if you want another layout for the editor. Here you can download Editor Skins. The contained sub folder must be copied to media/kunena/core/js/skins/ and the name of this skin must be entered to the configuration.
5 years 10 months ago - 5 years 10 months ago #215322 by 2078b54a0a6a52c894ea0efa
The again rich - I've figured this out now re. skins. I've downloaded the skin 'moono-dark' which looks rather nice.
I've also adjusted the spacing and group order on the edit bar - thanks to this post here:
www.kunena.org/forum/k-5-2-support/16055...s-changes-on-upgrade
Many thanks
Last edit: 5 years 10 months ago by 2078b54a0a6a52c894ea0efa.
