Solved My Kunena Forum doesn't work after I changed the address
5 years 11 months ago #214403
by shih
My Kunena Forum doesn't work after I changed the address was created by shih
I changed the site address of my joomla site. Everything works fine, except for my Kunena Forum. When I click on the Main Menu, my Kunena Forum just doesn't show, instead, the error message shows on that page as below:
load error: failed to find /home/readerai/public_html/components/com_kunena/template/blue_eagle5/assets/less/blue_eagle5.less
"readerai" is my old address. Can I do anything to fix this?
5 years 11 months ago #214405
by Leen
With kind regards
Leen
Replied by Leen on topic My Kunena Forum doesn't work after I changed the address
Maybe it helps if you are in the administrator area
The kunena menu ticks everything and has it rebuilt
with the button at the top?
Or go to administaror> components> kunena> Tools> menu manager and click on throw menu in trash
that has helped me sometimes
With kind regards
Leen
- Thank you received: 2540
5 years 11 months ago #214407
by rich
Replied by rich on topic My Kunena Forum doesn't work after I changed the address
5 years 11 months ago #214415
by shih
Replied by shih on topic My Kunena Forum doesn't work after I changed the address
Thank you. I cleared the cache and then it works!
