Solved
Kunena 5.1 - Anyone - how to customize our templates to allow larger Rank Imgs?
Kunena 5.1 - Anyone - how to customize our templates to allow larger Rank Images?
I would like to create larger Rank Images. How would one achieve such a feat and how large can I go without breaking the template? Which files would I need to edit and where are there locations?
Does the template for joomla matter on the answer to these questions? If so; I am using RocketTheme Latest "Ambrosia".
I am utilizing it on wethepeopleonline.com under "Assemblages" -> Nationwide Assemblages is Kunena utilizing the RocketTheme Joomla Style "Ambrosia"
My HTTPS is disabled at this time. You will have to manually change https:// (when it gives you an error - connection cannot be established / refused) to "http" which keeps being automatically changed with a plugin here on kunena forum.
