Solved The message has been successfully edited. NOT! Why?
6 years 1 week ago #214472 by Bobsaap
rich,
I did what you wrote, but everything is the same ...
I go to post from the year 2010, push the button Action > Edit and than edit it and push the button Submit.
After that I get this messages:
Notice: Cannot save message: Invalid email address!
Message: The message has been successfully edited.
And post is the same like before the editing ...
6 years 1 week ago #214474 by Bobsaap
And one more thing ...
If I'm editing the post, which is 1 month old, I can edit it without any problems.
6 years 1 week ago #214482 by Bobsaap
One more thing - is it possible to edit posts somewhere else?
Like in backend, data base, or ... and not in forum directly?
6 years 1 week ago #214486 by rich
/* * Check the local address * We're a bit more conservative about what constitutes a "legal" address, that is, a-zA-Z0-9.!#$%&'*+/=?^_`{|}~- * The first and last character in local cannot be a period ('.') * Also, period should not appear 2 or more times consecutively */
You findt this in the /libraries/src/Mail/MailHelper.php line 128. I'm not sure but maybe it has to do with your problem.
I have no idea what it means:
In the backend it's not possible but in the database you can do it. You find the text passages in the table #__kunena_messages_text.
The easiest way to find the right message, if you enter at the search option of phpMyAdmin a short text passage of this certain post.
If you have more hits, choose the hit in #__kunena_messages_text and edit the message.
6 years 1 week ago #214490 by Bobsaap
Thank you, rich!
I will do this through the phpMyAdmin - it works for me this way! ;)
