- Forum
- Community self help
- General questions and how-tos
- General Questions Archive
- Uploade images is displayed at max image size and not thumnail size
Kunena 5.2.1 Addons released (Today)
The Kunena team has announce the arrival of Addons (modules and plugins made by Kunena team) in version 5.2.1 which is now available for download. This version addresses most of the issues that were discovered since the release of Kunena 5.2.3. Download the Kunena Addons
Solved Uploade images is displayed at max image size and not thumnail size
When a forum user uploads an image, it will be automatically resized to he size which is et in the configuration. 800x800 px
So far so good.
But when we insert the image in a post, then the resized image is shown and not a thumbnail.
This is set in the configuration:
How can I change it somewhere so the thumbnail will be shown in the post instead of the full (resized) image?
Best regards,
Wouter
These are the configuration settings for the Images.
Maximum image width: 800px
Maximum image height: 800pox
Thumbnail width: 80px
Thumbnail height: 80px
The images in the forum posts are displayed with the maximum mage size (800x800)
And not as a thumbnail of 80x80).
I hope someone can help me to fix this.
Best regards,
Wouter
You have left the editor (maybe with the browser back option). This problem occurs if you use the browser back button and again the forwards button before save. Kunena register this as abort and enter no message ID for this image in the table row during save.I don't know why but I can not see my uploaded image in my post above.
This size is for thumbs below the message when the images are not inserted inside the message.The images in the forum posts are displayed with the maximum mage size (800x800)
If you want thumbs also in the messages, try this code in your custom.less.
.kmsgimage img {
max-width: 80px;
Thanks for your quick reply and explanation.
I added the extra css code t the custom.css file of the template.
But for as far as I can see nothing changed.
You can see an example here:
bmwcruiser.nl/forum/diversen/476-bmw-cru...up-in-corona-periode
All images do have a height of 800 px or a width of 800 px.
The owner of that website likes to see smaller images n the forum posts and when a visitor clicks at the small image that the popup will show the image at 800 px width and/or height.
Is that possible in Kunena?
Best regards,
Wouter
You must add the code in your custom.less, not css.I added the extra css code t the custom.css file of the template.
If you add the code in your custom.css you must add #kunena.layout at the begin.
#kunena.layout .kmsgimage img {
max-width: 80px;
Addition:
I see now, you don't use a template from us. If your template not offer this custom files, you can also add this code in your Joomla custom.css or template.css.
That was the difference. The Kunena template I am using is a Roundtheme temolate.
Thanks for the correct css code.
Best regards,
Wouter
Forum Access
- Not Allowed: to create new topic.
- Not Allowed: to reply.
- Not Allowed: to edit your message.
- Forum
