Solved Trying to post as guest and get error ''timeout-or-duplicate''
7 years 9 months ago #207692 by tomsson
htaccess: Exists | PHP environment: Max execution time: 150 seconds | Max execution memory: 128M | Max file upload: 128M
Joomla default template details : shaper_helix3 | author: JoomShaper.com | version: 2.5.6 | creationdate: Jan 2016
Kunena default template details : Crypsisb3 | author: Kunena Team | version: 5.1.2 | creationdate: 2018-07-15
Kunena template params:
Kunena version detailed: Kunena 5.1.2 | 2018-07-15 [ Charon ]
Third-party components: CommunityBuilder 2.4.0
Plugins: Search - Kunena Search 5.1.1 | Content - Kunena Discuss 5.1.1
Modules: Kunena Latest 5.1.1
How to fix this error ?
7 years 9 months ago #207695 by rich
You get this message if you multiple clicking with your mouse on the submit button. Users can't send the same message more than once in a certain time frame.
7 years 9 months ago #207697 by tomsson
7 years 9 months ago #207705 by rich
You have many wrong configured Kunena menu items.
1996 Forum main-menu view=home&defaultmenu=1998 forum 1999 NOWY TEMAT main-menu view=topic&layout=create forum/nowy-temat 1997 Kategorie main-menu view=category&layout=list&catid=0 forum/kategorie 1998 Ostatnie tematy main-menu view=topics&mode=replies forum/ostatnie 2000 Bez odpowiedzi main-menu view=topics&mode=noreplies forum/bez-odpowiedzi 2001 Moje tematy main-menu view=topics&layout=user&mode=default forum/moje-najnowsze 2002 Profil main-menu view=user forum/profil 888 Rozpocznij dyskusję menu1 view=topic&layout=create rozpocznij-dyskusje
Please repair this menu items it should solves your problem ( see here ).
7 years 9 months ago #207798 by tomsson
rich wrote: You have many wrong configured Kunena menu items.
Hey Rich
I remove all of Kunena menu items or all aliases called to Kunena menu items.. Removed also from the trash. After I used restore menu in the Menager Menu and this not fixed the problem.
Have you any other ideas?
7 years 9 months ago #207803 by rich
Ok, I found the issue. You have enabled both captcha plugins. If you want to use the plugin CAPTCHA - Invisible reCAPTCHA, you need a new registration at google for a code.
The same code as for CAPTCHA - reCAPTCHA does not work. Disable the plugin Invisible reCAPTCHA, it should solves your problem.
Time to create page: 0.165 seconds
