Solved Hiding the Legend row
I can do this with css however hiding the name of a group also hides those users from showing as online. Is there another way?
- Thank you received: 2545
rich wrote: Configuration -> tab Extra -> Show Who is Online = No
Thanks for the response however this doesn't work as it hides who is online. My post above states I'm just needing to hide the legend AKA user groups not the users themselves.
In principle it's easy to find the right css code. .unstyled.span11 is the relevant code for who is online. He contain a div with the span "Legend". If you add this to the code, it hiddens only the legend. In principle you can also hide single legends if you add also the class such as kwho-moderator.I can do this with css however hiding the name of a group also hides those users from showing as online.
Therefore the complete code (with Crypsis) should be:
