Solved Load/Display user avatar image inside post
7 years 11 months ago - 7 years 11 months ago #205774 by ante.resetar
Hi guys. I want to load user avatar image inside the post.
This is my template code inside template/crypsis/layouts/message/item/default.php and it displays created date, edited date, ID and username...
<small class="text-muted pull-right"> <?php if ($this->ipLink && !empty($this->message->ip)) : ?> <?php echo KunenaIcons::ip(); ?> <span class="ip"> <?php echo $this->ipLink; ?> </span> <?php endif; ?> <?php echo KunenaIcons::clock(); ?> <?php echo $message->getTime()->toSpan('config_post_dateformat', 'config_post_dateformat_hover'); ?> <?php if ($message->modified_time) : ?> - <?php echo KunenaIcons::edit() . ' ' . $message->getModifiedTime()->toSpan('config_post_dateformat', 'config_post_dateformat_hover'); endif; ?> <a href="#<?php echo $this->message->id; ?>" id="<?php echo $this->message->id; ?>" rel="canonical">#<?php echo $this->numLink; ?></a> <span class="visible-phone"><?php echo Text::_('COM_KUNENA_BY') . ' ' . $message->getAuthor()->getLink(); ?></span> </small>
After the username i want to display the user avatar. I'm not very skilled with PHP but i know you are :)
Thank you
Last edit: 7 years 11 months ago by ante.resetar.
7 years 11 months ago #205796 by ante.resetar
Any help much appreciated. Thank you
7 years 11 months ago #205808 by 810
try:
<?php echo $this->message->getAuthor()->getAvatarImage(KunenaFactory::getTemplate()->params->get('avatarType'), 120);
where 120 is the size.
7 years 11 months ago #205992 by ante.resetar
That worked like charm! Mark as solved. Thank you chief!
