Solved Can no longer access signatures.
7 years 10 months ago #202675 by KZQ
I've been struggling with new versions and incompatibilities with the Blue Eagle5 template. Before I found Blue Eagle5 1.5.0-RC3-DEV members could not edit their profiles. Now that I changed the template to this DEV version we can edit most of our profiles but the individual signatures are not accessible. I'm using Joomla 3.8.10 Kunena 5.1.2.
Any help will be appreciated.
Bill
7 years 10 months ago #202677 by 810
I will release tomorrow a new blue eagle version, there it should work.
7 years 10 months ago #202680 by KZQ
Thank you very Much!
I should have also said that presently the existing signatures are showing twice with each post.
Bill
7 years 9 months ago - 7 years 9 months ago #203839 by KZQ
Hi 810,
I have downloaded the newest version of Blue Eagle5.
Unfortunately, now the signatures and the text of the posts are displayed over each other.
Thanks for your help.
Bill
Last edit: 7 years 9 months ago by KZQ.
7 years 9 months ago #203842 by 810
looks like a conflict with your joomla template. do you have a link to a topic with this issue.
7 years 9 months ago - 7 years 9 months ago #203846 by dirk.potyka
Well, another me too here.
The signature is not below the texts as usual but higher positioned so that it appears overlayed by the texts of the posts.
E.g.; www.rcboot.de/index.php/forum/uservorste...euer-in-bayern#35813
(Posts from "Chaos")
This started when updating to 1.5.0 (not sure if it was already with RC3 but I do not think so)
Last edit: 7 years 9 months ago by dirk.potyka.
