Solved Only allow forum admins to include links in posts?
  • Test999
  • Test999's Avatar Topic Author
  • New Member
  • New Member
8 years 4 months ago #202604 by Test999
Does anyone know if there's a way to setup Kunena so that only forum admins or mods can include links in posts? So the main user base would be prevented from adding links to posts.
And are there any plans to be able to edit posts in the back end?
Thanks.
8 years 4 months ago #202608 by rich
Configuration -> Security -> Max Links in message = 0
This limit is only for registered users, not for Admins and Mods.
But I've noticed, there is a bug. it works only on Reply, not when Mods or Admins create a new topic. In the first message of a topic applies this limit also for mods and admins. But they can insert links with a trick also in the first message if they are after saving edit the message.
I will add this in the bug list.
No idea, but if you want discuss about this, then ask in the correct category please. Different discussions in a topic are not welcome.
www.kunena.org/forum/119-Feature-Requests
The following user(s) said Thank You: Test999
  • Test999
  • New Member
  • New Member
8 years 4 months ago #202609 by Test999
Hey! Thanks so much :) I did see that max link setting but assumed it would affect everyone. I'll give it a go with the edit workaround.
Thanks again.
  • Test999
  • New Member
  • New Member
8 years 4 months ago #202610 by Test999
Just to confirm I tried the workaround and it works fine. I'd like to mark this post as solved.
Time to create page: 0.151 seconds
