Solved [SOLVED] About Social sharing button tags
8 years 7 months ago - 8 years 7 months ago #199059 by webmasterinaffitto
I'm using Crypsys template on kunena forum 5.0.14 and I've turn on the social sharing button.
The question is: I don't want all those button, but just some of them. I've noticed I can choose personal tags, but not understand how it works... What I've to write to see only facebook, twitter, instagram and g+ button?
Thank you
Last edit: 8 years 7 months ago by webmasterinaffitto.
8 years 7 months ago #199063 by 9themestore
Try to use css to disable all buttons you don't want to show. That is the simple solution with this case.
8 years 7 months ago #199065 by webmasterinaffitto
I've thought about this, using the .less file but:
1) On every upgrade I need to modify it again
2) Deleting the less instruction from the file I eliminate the buttons or only the graphic appearence of them?
3) If there is a function into Crypsis template configuration, why there is no way to understand how it works? :blink:
8 years 7 months ago #199066 by 9themestore
If you don't want to modify again after upgrade template, you should add the CSS rules to disable social buttons in the style file of joomla template default. An other solution you can use the Addthis and custom tag to show some social button you want.
The following user(s) said Thank You: webmasterinaffitto
8 years 7 months ago #199067 by webmasterinaffitto
9themestore wrote: If you don't want to modify again after upgrade template, you should add the CSS rules to disable social buttons in the style file of joomla template default. ...
Good, can you tell me the code to add to override?
8 years 7 months ago #199073 by ruud
or use the jssocials plugin, same buttons, better control: onlinecommunityhub.nl/community-tools/th...ng-buttons-in-kunena
sharing = caring
