Solved Garbled posts in Google Chrome [solved]
8 years 7 months ago - 8 years 7 months ago #198993 by toivo
A user posted this issue to the Joomla forum. Use Google Chrome, login and the posts are garbled. Log out, view the same post and it is displayed all right. Other browsers appeared to work ok, but some users complained also about other browsers.
Could Cloudflare and its SSL certificate have something to do with the decompression of the HTML going haywire in Chrome, which has recently been keen to report issues in security certificates?
Regards,
toivo
Last edit: 8 years 7 months ago by toivo. Reason: marked as solved
8 years 7 months ago #198997 by 810
Replied by 810 on topic Garbled posts in Google Chrome
Yes, can be cloudflare. or other cache system, but 80% its local browser issue. He/She should remove cookies and browser cache. (Also PWA cache if supported - console - application - delete all option there ).
8 years 7 months ago - 8 years 7 months ago #199012 by toivo
What is PWA cache and in which browser and console can I find it?
As I mentioned in the earlier topic, the issue of garbled messages has now gone away.
8 years 7 months ago #199014 by 810
PWA = Progressive Web Apps
8 years 7 months ago #199016 by toivo
Thanks. PWA does not seem to be activated because there were no entries under Cache - Cache Storage or Application Storage.
Regards,
8 years 7 months ago #199017 by 810
yes, its now turned on for users on kunena.org, but on that page there are some cache tabs, where you can try to clean the cache.
But it is already working for you.
