- Thank you received: 1
Solved Garbled posts in Google Chrome [solved]
A user posted this issue to the Joomla forum. Use Google Chrome, login and the posts are garbled. Log out, view the same post and it is displayed all right. Other browsers appeared to work ok, but some users complained also about other browsers.
Could Cloudflare and its SSL certificate have something to do with the decompression of the HTML going haywire in Chrome, which has recently been keen to report issues in security certificates?
Regards,
toivo
As I mentioned in the earlier topic, the issue of garbled messages has now gone away.
Regards,
But it is already working for you.
