Solved Restore a deleted user
8 years 7 months ago #198924 by maxstorch
By mistake, I deleted a user from Joomla. After this the user has registered in Joomla once more, but all his previous messages in Kunena forum are shown now without avatar and profile. Is it possible to connect the new user to the old one? If this is impossible, can I restore the old user and his profile?
Thanks in advance to your help.
8 years 7 months ago #198928 by rich
Replied by rich on topic Restore a deleted user
If you delete a user then the user is gone. Joomla has no option to restore deleted users. You can restore the user if you have a database backup, otherwise it looks no good.
8 years 7 months ago #198934 by maxstorch
Replied by maxstorch on topic Restore a deleted user
It seems I have a database backup. Can you give me a hint how to export the deleted user to the current database?
And is it possible for the site administrator to edit avatar of another user?
Thank you for help, I am just a beginner in Joomla. I am ready to donate to Kunena development.
8 years 7 months ago #198965 by rich
If you delete a user, he will removed from the Joomla tables *__users and *__user_usergroup_map
Have you experience with phpMyAdmin?
1.) Open the __user table with phpMyAdmin and add a new user
Add all relevant informations from the deleted user in the fields (such as ID, register date and so on..). You find this informations in your backup file if you to open this with a text editor such as notepad plus.
2.) Add this user ID to the table *__user_usergroup_map
3.) Go in backend to Kunena -> Tools and to synchronize the users and recount all statistics (that's all, the user should be back again).
Important! Create a new databse backup previously! For interventions in the database, I take no guarantee! If a mistake happens it can to destroy the entire page!
7 years 11 months ago - 7 years 11 months ago #205741 by lemur
Replied by lemur on topic Restore a deleted user
I have a similar story. One administrator has deleted the user from Joomla.
I created a new user with the same name and username again and restored his previous ID in the database in the #__users and #__user_usergroup_map tables.
All posts of this user are saved in the database, since the forum was not cleaned with Kunena tool afterwards.
The "name" and "userid" fields in the _kunena_messages table contain the correct (old) name and id.
But Kunenа considers this user as new (synchronization did not help) and does not connect this user with the posts written by him.
Question.
Is it possible to attribute to the user his posts (several hundred) using the manipulations in the tables of kunena?
P.S. in _kunena_topics table "userid" (f.e., first_post_userid) and "name" (first_post_guest_name) are also correct.
Signature:
Many thanks to Rich and the other advisors.
Last edit: 7 years 11 months ago by lemur.
7 years 11 months ago #205762 by rich
Have you created this user via database or via Joomla backend?
I've tested it.
1. Created this user with same name and user name in the Joomla backend (it will create all user relevant entries).
2. Note down the user ID from the Joomla user manager
3. Adjusted the ID in the tables *__users and *__user_usergroup_map (group ID 2)
All is corrct again, so i think, you should check it again.
