Solved Once again a question about updating
8 years 7 months ago - 8 years 7 months ago #198828 by balo2109
Hi folks,
i´m pretty sure this question was asked already, but the search didn´t really help.
I would like to update from 4.x to 5.x on my joomla site.
Simple question: Is this the right way to do it?
Download the latest version from the Kunena website as a zipped file.
"Install" the new version using the joomla installer to upload the zip file.
This works, without corrupting my catagories, post, users etc?
Some help is much appreciated.
Greetings
Michael
Last edit: 8 years 7 months ago by balo2109.
8 years 7 months ago #198843 by rich
Yes, everything remains, but we still recommend a complete backup, errors could always happen. In Kunena 5.0 is removed the template Blue Eagle, maybe you must also adjust the style. Therefore you should test it previously on a test page.
8 years 7 months ago #198844 by balo2109
Great
Thx, Rich
8 years 7 months ago #198881 by balo2109
So, now i updated the forum more or less successful, which means, the site is running, i can see the topics and so on.
But my template is all messed up.
Since i had no other choice, i changed the default template to "crypsis".
I can´t see the Kunena menue anymore and got some entries twice.
Please, i need some help on this. What kind of setting do i have to choose?
Greetings,
Mike
8 years 7 months ago #198891 by rich
Please read this doc: docs.kunena.org/en/troubleshooting/menu-issues
8 years 7 months ago #198892 by balo2109
thx for your reply Rich.
I was already able to sort it out.
So my problem is solved.
Agaimn, thanks for your support.
Time to create page: 0.217 seconds
