Solved Kunena emails not sending
8 years 8 months ago #198482 by Matthieu OOT
Hello Kunena community,
I have been using Kunena on my website www.outoftrack.com for a couple of months now.
I noticed yesterday the email delivery doesn't work.
I tried to recover my login details but nothing arrived to my mail box.
It was working before though. I suspect the latest kunena update which I installed earlier this week to be at the origin of the issue.
I checked existing threads. My settings are fine.
I therefore suspect a conflict with my template.
My template provider won't help as this is a third party extension.
Could anybody advise how to locate and fix the issue please?
Thank you very much!
Matthieu
8 years 8 months ago #198486 by rich
Replied by rich on topic Kunena emails not sending
Which emails do you mean? Registration confirmation or emails to subscribers?
Please create a configuration report: docs.kunena.org/en/faq/configuration-report
8 years 8 months ago #198528 by Matthieu OOT
Thank you Rich.
Both emails do not work:
1/ Wanted to recover my password, but no email is sent to me after I informed my email address in the "Forgot your password?" section.
2/ Wanted to test email registration, but no email sent either with the activation link.
Please find below the configuration report:
htaccess: Exists | PHP environment: Max execution time: 300 seconds | Max execution memory: 256M | Max file upload: 256M
Joomla default template details : theme1746 | author: TemplateMonster.com | version: 2.1.0 | creationdate: April 2013
Kunena default template details : Crypsis | author: Kunena Team | version: 5.0.13 | creationdate: 2017-12-31
Kunena template params:
Kunena version detailed: Kunena 5.0.13 | 2017-12-31 [ Meerkat ]
Plugins: None
8 years 8 months ago #198534 by rich
Check your spam folder, maybe the mails are in it. But I think, you've generally a problem with your mail-transmission. The mails are to sent via Joomla. When this not work, you get also from Kunena no mails.
8 years 8 months ago #198541 by Matthieu OOT
Thank you Rich.
Nothing in my spam folders.
Emails sent via joomla!/our website work. Only emails from Kunena do not work.
So the configuration report doesn't show any problem?
If there is an override issue with the template, would the report say so?
Thank you for your usual support.
8 years 8 months ago #198545 by rich
This confirmation mails you should get from Joomla. Kunena has nothing to do with this mails, becouse Kunena has no own registration. And if you click on "Forgot your password?", there is only a redirect to the Joomla form.
Therefore I had written:
>> The mails are to sent via Joomla. When this not work, you get also from Kunena no mails. <<
I'm sorry, no. I see only whether your Kunena settings are correct.
Time to create page: 0.153 seconds
