Solved Change quote layout
My problem is the kunena template is using the same quote layout as for the lighthouse template.
Quote is without a box and text is center. I want to change that, but i don't know how.
I found this:
/components/com_kunena/template/canvas/assets/less/general.less
i tried this:
But that doesn't changed anything.
I would be happy for any help!
- 9themestore
- Premium Member
I can't found the Canvas template on the arrowthemes.com, so I can't help you debug this question. Please post your site's url here, I'll help you check and suggest a best solution to you.
- 9themestore
- Premium Member
Try to update your css rules to the custom.css file in the "components/com_kunena/template/canvas/assets/css/" path. After update you should clear Kunena's cache.
Send me email, if it does not work. I'll help you solve it.
i added this code to "components/com_kunena/template/canvas/assets/css/"
i cleared kunena, joomla and my browser cache, avaland.de/de/forum/test-dummy/4-test#8but nothing changed so far .
- 9themestore
- Premium Member
