Kunena 6.0.9.1 Released
The Kunena team has announce the arrival of Kunena 6.0.9.1 [K 6.0.9.1] which is now available for download as a native Joomla extension for J! 4.2.x. This version addresses most of the issues that were discovered in K 6.0 and issues discovered during the development stages of K 6.0.
Solved Just installed Kunena 5.0.12 over 4.0.12 and my customization disappears ?
- Chacapamac
- Junior Member
5 years 3 months ago - 5 years 3 months ago #1
by Chacapamac
Just installed Kunena 5.0.12 over 4.0.12 and my customization disappears ? was created by Chacapamac
I just installed Kunena 5.0.12 over 4.012 and my customization disappears. I revert to before the upgrade.
What can I do to be sure that I keep the customization on upgrade?
Last edit: 5 years 3 months ago by Chacapamac.
5 years 3 months ago #2
by ruud
sharing = caring
Replied by ruud on topic Just installed Kunena 5.0.12 over 4.0.12 and my customization disappears ?
How and where did you do the customizations? Did you change .php files or did you use the Kunena template .css / .less override possibility?
sharing = caring
- Chacapamac
- Junior Member
5 years 3 months ago - 5 years 3 months ago #3
by Chacapamac
Replied by Chacapamac on topic Just installed Kunena 5.0.12 over 4.0.12 and my customization disappears ?
I think I simply put the css in my custom site css
I just see your docs for the overrides, it’s for the avatar, what will be the override for the complete visual ?
5 years 3 months ago #4
by ruud
sharing = caring
You can add custom css via your templates custom css function (if your template supports that) or you can goto
back-end > components > kunena forum > templates
then select (radio bullit) your kunena template and press the button (top bar) [Edit CSS]
in the list of css files there is a custom.css
Every customization you put in here should 'survive' updates as this file is not overwritten during an upgrade.
Not sure if it will respect these changes with the 4.x to 5.x upgrade as this is a majot upgrade. But the you can add the required changes back when upgraded
sharing = caring
- Chacapamac
- Junior Member
5 years 3 months ago #5
by Chacapamac
Thanks - You can close that ticket
Merry Christmas to All!
