Solved Modify Subject EMail Notification
8 years 11 months ago #197014 by mario87
i am trying to change the subject line for the email notifications for the subscriptions.
The default setting for the subject is: title (category)
Is it possible to change the subject line?
I am looking in the default.php in the folder: com_kunena\template\templatename\layouts\email\subscription\
I try to change the variable $subject. But these change doesn't work.
The mails sent in plain format.
I look forward to hearing from you soon.
best regards
Mario
8 years 11 months ago #197057 by 810
you should edit all files in the email dirs.
components\com_kunena\template\templatename\layouts\email
Then it should work.
8 years 11 months ago #197072 by mario87
Hi thanks for this information.
The problem is still there.
The subject in the mailbody is gone but the subject line in the mail is still there.
HTML example:
Notice: Undefined variable: subject in \components\com_kunena\template\crypsis\layouts\email\subscription\default.php on line 165
Betreff :
Kategorie : News
I deleted all subject variables in the three files.
Is there any other file, where i can change the subject for the Mail?
best regards
Mario
8 years 11 months ago #197095 by mario87
a few news:
i have renamed all files in components\com_kunena\template\templatename\layouts\email.
The notification works!
The file default.php in components\com_kunena\template\system\layouts\email\subscription sents the notification mail.
The subject line isn´t set in this file. I set comments to find the subject line.
Where is the place to find the subject line for the notification mails?
best regards
Mario
8 years 11 months ago #197180 by mario87
Are there any news?
this is the last "problem" to solve. after that the forum 'll go online.
i looked in other files. for example in the com_mailto.
best regards
Mario
8 years 9 months ago #198314 by bcraigie
In libraries/kunena/forum/message/message,php on line 397 you can change the subject line. For example:
$mailsubject = JMailHelper::cleanSubject ( $topic->subject . " (" . $this->getCategory ()->name . ")" );
change to
$mailsubject = '[My Site Name] '.JMailHelper::cleanSubject ( $topic->subject . " (" . $this->getCategory ()->name . ")" );
This prepends [My Site Name] to the email subject line. I don't know why this obvious requirement has not been parameterised. Be aware that when Kunena is updated, this file could be overwritten.
Hope that helps.
The following user(s) said Thank You: mario87
