Solved no searchmask visible
9 years 5 days ago - 9 years 5 days ago #196821 by Tom01
no searchmask visible was created by Tom01
I'm using Joomla 3.8.2 and Kunena 5.0.11.
If I click in the kunena menu "search" I can't see any input fields. I don't know how long the searchmask isnt shown
but this is deadly for a board ;-)
Also with the crypsis standard template is the same.
Under plugins "search - kunena" is activated.
Hope you'll have any hints for me?!
Thank you,
Tom
Last edit: 9 years 5 days ago by Tom01.
9 years 5 days ago #196825 by rich
Replied by rich on topic no searchmask visible
This plugin has nothing to do with the frontend search. The search options are only closed. I don't know your template, but go with your mouse on right. Maybe the /open/close buttons are only with visible if you go with the mouse over it.
9 years 5 days ago #196826 by Tom01
Replied by Tom01 on topic no searchmask visible
rich wrote: I don't know your template, but go with your mouse on right. Maybe the /open/close buttons are only with visible if you go with the mouse over it.
Where should do that? Backend under plugins?
"Ich steh auf dem Schlauch!" ;-)
merci
9 years 5 days ago #196828 by rich
9 years 5 days ago #196831 by Tom01
oh thats interessting. I don't have this button. Also If I try to mark the content of the site with the left mouse button - there isnt something.
I'll try that with the standard template. But at moment are some maintenance on my site. Have to wait.
thx
9 years 5 days ago #196832 by Tom01
There was a style conflict with my joomla template (not the kunena template).
Got some support from 9themestore.
Thank you as well!
Time to create page: 0.176 seconds
