Solved Kunena Poll background color
9 years 2 weeks ago #196696 by Nikiniko
How can i make all the lines to have same background color
prntscr.com/h7q1au
Stop zebra effect :)
9 years 2 weeks ago #196710 by Nikiniko
somebody ?
9 years 2 weeks ago #196728 by rich
Replied by rich on topic Kunena Poll background color
Please try this code in your custom.less , then empty the cache.
Check also other tables, I'm not 100% sure whether this color is also displayed on another place (such as statistics). But in principle should this change only displayed at poll.
.layout#kunena table.table.table-striped.table-bordered.table-condensed tbody tr td { background-color: #555; }
The following user(s) said Thank You: Nikiniko
9 years 2 weeks ago #196736 by Nikiniko
rich wrote: I'm not 100% sure whether this color is also displayed on another place (such as statistics).
}[/code]
If yes i will let you know
9 years 2 weeks ago #196737 by Nikiniko
I tried it in the custom less of Kunena template but it didnt work
:ohmy: :ohmy: :(
9 years 2 weeks ago #196738 by Nikiniko
i had to clean to cache from nginx too,
now all are ok
