Solved How to disable updates?
9 years 4 months ago #188273 by Zemran
I have tried very hard to work with version 5 but it is not fit for the job. Up until version 4.0.12 I do feel that this was a brilliant product, the best but I do not like 5. Not just the lack of decent themes but it does not work well with my site. Lots of problems like 2 dropdowns and text all over the place.
I deleted v5 and had to remove all entries from the database as you cannot simply go back to v4. Now it wants to upgrade to v5 again. How can I take it off the update list so it stops nagging me? I love v4 and do not want to have delete it altogether.
9 years 4 months ago #188279 by Zemran
Replied by Zemran on topic Solution found.
From the menu system - Extensions -> Manage -> Update Sites and delete the Kunena update site. Kunena are not going to produce any updates so there is no loss. I can now stick with v4 and I hope we can all be happy :D
