Solved Bad quality of avatar
9 years 7 months ago - 9 years 7 months ago #185155 by tomsson
Hi
How to make better quality of avatars?
Last edit: 9 years 7 months ago by tomsson.
9 years 7 months ago #185157 by rich
Replied by rich on topic Bad quality of avatar
You use the Community Builder? Please see here: www.kunena.org/forum/general-questions-a...lurred-profile-image
9 years 6 months ago #185578 by djangothebest
Replied by djangothebest on topic Bad quality of avatar
I have exactly the same issue.
But still not able to fix the problem. Even with the linked topic.
Can anyone help me please.
THX
9 years 6 months ago #185583 by rich
If you have changed the thumbnail size, you must upload the avatar again.
9 years 6 months ago #185616 by djangothebest
I did, but the quallity in a forums topic is still bad :-(
9 years 6 months ago #185617 by djangothebest
Solved.
I changed the settings in the CB Configuration-Avatar several times and now I found a setting which works for me.
I set the standard max size for the picture to 300 and the standard max size for the preview picture to 150.
If I change the preview picture size back to the default value of 86x60 I have again the problem with the bad quality.
So, as I said, the above setting works for me.
Thx for your support.
