Solved Kunena 5.03 Menu Background Color
10 years 3 weeks ago #181250 by allenjj
The default menu background color for the crypsisb3 is gray with the menu options in white which makes it impossible to see. How do I go about changing the background menu colors?
htaccess: Exists | PHP environment: Max execution time: 660 seconds | Max execution memory: 512M | Max file upload: 360M
Joomla default template details : t3_bs3_blank | author: JoomlArt.com | version: 2.2.3 | creationdate: July 22 2016
Kunena default template details : Crypsisb3 | author: Kunena Team | version: 5.0.3 | creationdate: 2016-10-23
Kunena version detailed: Kunena 5.0.3 | 2016-10-23 [ Dibatag ]
Third-party components: AltaUserPoints 1.1.5 | CommunityBuilder 2.0.15 | UddeIM 3.9
Plugins: Search - Kunena Search 5.0.1 | Content - Kunena Discuss 5.0.1
Modules: Kunena Latest 5.0.1 | Kunena Stats 5.0.1 | Kunena Login 5.0.1 | Kunena Search 5.0.1
10 years 3 weeks ago #181251 by 810
add this on the custom.less file from crypsis:
.navbar-default .navbar-nav > li > a { color: #000; }
10 years 3 weeks ago #181252 by allenjj
Can I do that as a custom.css file? Im not familiar with creating less files.
10 years 3 weeks ago #181253 by 810
backend - kunena - template - select crypsis - select edit less - select custom.less - paste the code- save
10 years 3 weeks ago - 10 years 3 weeks ago #181254 by allenjj
I edited the custom.less pasting the code exactly as shown, saved and then exited. Then cleared the cache and nothing changed. You can see the recent topics menu item but the others with white on gray disappear.
Last edit: 10 years 3 weeks ago by allenjj.
10 years 3 weeks ago #181256 by 810
then try
.navbar-default .navbar-nav > li > a { color: #000 !important; }
The following user(s) said Thank You: allenjj
Time to create page: 0.153 seconds
