Solved Changing text "category header"
10 years 3 months ago #178074 by geejay
Hi there. I'm new to Kunena and have been impressed how easy it is to install and set up... well done!
I have just one small issue, in that each area has the text "Category Header" is it possible to change this to the actual name of the category?
I have attached an example image below from the Welcome Mat.
Attachment not found
10 years 3 months ago #178075 by geejay
Hi, tried attaching the image with the insert button, nothing happens.. but hope you might know what i mean =)
10 years 3 months ago - 10 years 3 months ago #178076 by rich
You mean the category header in Blue Eagle? This is unfortunately not possible. Unless that you want in principle another definition instead of "Category Header".
Last edit: 10 years 3 months ago by rich.
