Solved Profile problems
10 years 4 months ago - 10 years 4 months ago #177143 by dimoss
Profile problems was created by dimoss
Hi
I wonder how it is possible to have also the real name in the profile together with the username.
See attached image..
Also is it possible to tell me which files i need to fix in order to get the correct registration date and the correct time in the profile settings.
I use Greek language and I remember I had solved this problems before in K 3.0.6 but since then it's a lot of time and I can't really remember what I did! :)
The only thing that I remember about is that I should edit a file because the short code for date and time was written in Greek characters instead of English!
Any help is appreciated
Last edit: 10 years 4 months ago by dimoss.
10 years 4 months ago - 10 years 4 months ago #177153 by dimoss
Replied by dimoss on topic Profile problems
Hi
I solved the problem with date and time fixing the el-GR.com_kunena.libraries.ini in the Administratot/language folder.
However I still cannot find to add the real name together with username
10 years 4 months ago #177156 by 810
Replied by 810 on topic Profile problems
you can choose 1 or the other, not both.
Else you need to customize the template.
10 years 4 months ago - 10 years 4 months ago #177157 by dimoss
Hi
I have chosen from the Configuration to display the real name but in the profile it shows the username.
How is this possible?
See attached..
It shows the name in the greeting but in Profile shows the username. I want there to be also the real name
And if I need to hack the template which file? What line?
Tnx
10 years 4 months ago #177160 by 810
The following user(s) said Thank You: dimoss
10 years 4 months ago #177161 by dimoss
Yeap! Now it's ok..
Thanks!
