- Thank you received: 2
Solved Kunena 5 RC Releases Upgradable?
- eSilverStrike
- Junior Member
Will I be able to upgrade the release candidates as new ones comes out and when the final release comes out without loosing all my config info and data?
- eSilverStrike
- Junior Member
K5 does seem pretty stable (since it is now out of beta and is a release candidate).
I am using the new Crypsisb3 template since my Joomla site template already uses bootstrap 3.
As far as the stability of K 5.0 is concerned, that's a matter of opinion. I agree with @Josh that there are issues with styling that affect the UX but I would add that there are bigger problems with the UI. However, given the history of development with K 4.0, there are a few question marks surrounding the stability of the feature set within K 5.0. Will new features be added that break parts of the system that previously worked; that kind of thing.
Unlike K 4.0 which effectively went through ten beta releases (during which time there were new features—some of which affected third-party template developers—added to the core) until K 4.0.6 was released, K 5.0 has been relatively more "stable". The bigger problems with the overall UX are, in my opinion, more to do with how users of Crypsis will adapt to the new appearance and layout of the forum controls. It is for reasons of the stability of the feature set, given the experience of K 4.0, that will prevent many people from adopting K 5.0 after the first "stable" version is released.
Overall, it would seem that should be few (if no) technical reasons preventing people upgrading Kunena.
You can always downgrade, or update later again.
