- Thank you received: 2
Solved Does Kunena Support Joomlas Tags Component
- eSilverStrike
- Junior Member
Tom
- eSilverStrike
- Junior Member
Is there an easy way to display a module in a side column that shows related articles (or other info) for particular forum topics.
Ideal this would have be one module using info from the Joomla Tags component which I would have tagged specific forum topics manually as they come up.
I know Kunena has it's own tagging system. I am sure my type of situation has come up before, how do others handle it?
Tom
There is a module for that, you can see it on the joomla extensions dir.
- eSilverStrike
- Junior Member
Also I have checked for other modules on the Joomla Extension directory and don't see one that allows me to show related articles based on what Kunena forum topic is being displayed (or something similar). Which one where you thinking of?
Thanks for the support.
Tags is not working at all, you can save the tags, but it doesn't do anything, just plain text, thats why we removed it, And in the mean time Joomla has now their own tags. So we still need to implent that to. But we are on a small team, 2 devs and 1 moderator.
Fixing bugs is our priority.
