Kunena 6.1.3.2 Released
The Kunena team has announce the arrival of Kunena 6.1.3.2 [K 6.1.3] which is now available for download as a native Joomla extension for J! 4.2.x/4.3.x. This version addresses most of the issues that were discovered in K 6.1.0 and issues discovered during the last development stages of K 6.1
Solved Convert Kunena 2.x template to Kunena 4.x
- adellaguardia
I assume this is because it's a 2.x template installed in a 4.x Kunena installation.
Can you please point me to a tutorial on how to convert an old Kunena 2.x template to 4.x? I don't think the site I purchased the template from monitors support or responds to support requests, so rather than giving up and throwing away my employer's money, I want to try to convert the template instead.
Thank you!
All code should work, if you have errors, then its means that its old J1.5 code. Then you need to find the correct string on the blue eagle template.
Ps blue eagle (none -hmvc) template will not run on K5.0
- adellaguardia
So there's no way to upgrade an old template? What if I were to create a new template, could I copy anything from the old template over so they look identical?
Hmmm .. there are at least 20+ files that you will need to competely replace. By the time you've made those replacements, you will probably have lost most of the "advantages" that you thought you were getting with the product you had [unfortunately] purchased.adellaguardia wrote: Well crud
I've done this before but it's time-consuming and there's no real benefit. To create a new K 4.0 template (based on Blue Eagle) takes me about two or three days of dedicated effort. I've never attempted to create a new template based on Crypsis but I imagine the effort would be similar. Further, speaking as a former developer of third-party templates for Kunena, there was no profit in it for me. I stopped building my templates because the core code kept changing from one minor release to the next and those changes continually my templates (and all the other third-party templates, too). But, if you want to do try it, go ahead and good luck.
- adellaguardia
Thank you for explaining it to me.
