Solved How to prevent registered users from seeing user list
10 years 5 months ago #176275 by webdevtim
I have look at every setting and I can get the "User List >>" link to go away. I don't want the names of any users displayed on this site. I don't just want to use CSS display: none because someone could easily change that to display:block with FireBug. So I want to disable this at the PHP level.
Thanks you in advance for any suggestions.
10 years 5 months ago #176282 by webdevtim
OK, then I should be able to disable the display of the User List in Blue Eagle. Which PHP file do I edit??? If you know, let me know, so I don't have to spend a lot of time hunting it down.
10 years 5 months ago - 10 years 5 months ago #176284 by sozzled
webdevtim wrote: OK, then I should be able to disable the display of the User List in Blue Eagle. Which PHP file do I edit?
Well, strictly-speaking, it's not a case of disabling the "display" within Blue Eagle; it's a matter of crippling the functionality within Kunena.
If I am to understand correctly that you want to prevent any registered user being able to display the userlist in Kunena—the words "User List" displayed on a webpage regardless—I think the file you want to examine is ../components/com_kunena/controllers/user.php.
Last edit: 10 years 5 months ago by sozzled.
10 years 5 months ago #176294 by webdevtim
Thank you ever so much.
