Solved Displaying the Advanced Search option
10 years 5 months ago #176032 by kook
We have a forum setup (version 4.0.10 on Joomla 3.5) with the Kunena Search Plugin 3.1.2 installed and this does enable a simple search of the forum topics.
What I'm trying to achieve is the same Advanced Search functionality as is shown on the kunena.org forum. Is there an additional extension needed for this? I could only see a single search option within the Kunena section of the menu assignments.
Everything else about the forum is working great, just need to finish off the search functionality.
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 128M
Joomla default template details : gk_simplicity | author: GavickPro | version: 3.9 | creationdate: 12 Jun 2013
Kunena default template details : Blue Eagle | author: Kunena Team | version: 4.0.10 | creationdate: 2016-02-18
Kunena version detailed: Kunena 4.0.10 | 2016-02-18 [ Villavicencio ]
Third-party SEF components: sh404sef 4.4.4.1791
Plugins: Search - Kunena Search 3.1.2
10 years 5 months ago #176033 by 810
1) We have a default search, see the search tab
2) Then we have a plugin called Kunena Search Plugin, that's tells the default joomla search to search also on kunena forum.
3) we have a module, there you can do simple search.
