Solved How Can I Export data from 1.9 to kunena 4
10 years 5 months ago - 10 years 5 months ago #175838 by idc
Hi
I need to export all forum data from on old server, that needs to stay as is; to new server.
Is there another way to export the data straight into kunena?
It seems odd that you can import from other forums, but not from previous kunena.
Thanks in advance.
Last edit: 10 years 5 months ago by idc.
10 years 5 months ago #175850 by 810
you only need to import the *_kunena tables, and user/usergroup tables from joomla.
Make sure you have the same prefix
