Loved Show/hide tabs
10 years 6 months ago #175204 by escl
Show/hide tabs was created by escl
Hi guys can you please give me the path to show/hide the tabs
"My topics"
"Recent topics"
"No replies"
etc etc
Thank you
Maria
10 years 6 months ago #175206 by ruud
Replied by ruud on topic Show/hide tabs
thse are in the Kunena menu.
Back-end > Menus > Kunena Menu
here you can publish / unpublish and set specific user rights (show or no show on acl group membership)
hope the helps :0
sharing = caring
The following user(s) said Thank You: escl
10 years 6 months ago - 10 years 6 months ago #175207 by nutter308
Replied by nutter308 on topic Show/hide tabs
[strike]I'm not aware of any AdminCP options to disable the preset forum menu's.
You can use CSS override to hide them
Hide the whole menu Example:
#ktab { display: none; }
[/strike]
Disregard my post I was not aware of the above :)
Last edit: 10 years 6 months ago by nutter308.
10 years 6 months ago #175211 by escl
Replied by escl on topic Show/hide tabs
Hi Ruud and thanks for your answer
All menu items are published but the tabs dont show up
Is there another setting that can prevent these tabs to show?
Thank you
Maria
10 years 6 months ago #175214 by 810
Replied by 810 on topic Show/hide tabs
they will only show up, when you are login.
Else you need to change the permission on the menu item.
10 years 6 months ago #175274 by rich
Replied by rich on topic Show/hide tabs
The tabs are also not present if you use wrong menu items.
www.kunena.org/docs/en/troubleshooting/menu-issues
